wveng25
- May 14, 2015
- 2
We are having problems with a VFD, at a Pump Station, having "HW Overcurrent Faults" after the weekly generator exercise event. The odd thing about the fault it does not happen when the weekly exercising of the generator occurs, but it happens approximately 3 to 6 hours, or more after the generator runs. There appears to be some connection between the VFD faulting and the generator weekly exercise, but all parties are at a loss as to what it may be. The generator is a Kohler 100KW/125kVa natural gas fired. The service is 277/480 volt 3 phase. The VFD is a Allen Bradley Power Flex 400 and it is used for a Pump Station with 2- 24.8 HP, 460 volt submersible pumps. Has anyone ever run across this time of problem before or have suggestions for possible causes of this problem.
