I'm looking for a VFD for a 0.37 kW induction motor in a machine which would be used in environments requiring EMC category C1. The machine must also be connected to mains with a regular plug. This has turned out to be quite hard.
The plug connection limits the ground leakage current to 3.5 mA at max. On the other hand category C1 requires heavy filtering which increases ground leakage. Several VFDs have an option to disable the internal EMC filter to reduce ground leakage but it will make EMC compliance even harder.
Is it possible at all to achieve both with off the self hardware?
