Hello, I have VFD and 2 motors One of them is manufactured by WAT and other by VOLT, both of them are made in Turkey. In first case when I connect VOLT motor it works good on 10-100HZ range, in second when I connect WAT motor it start vibrating at 40HZ. I tried to connect WAT motor with another VFD and it worked without vibration. What can i do to get proper work of motor.
