Hey, I am making my own dynamometer setup, and I bought a 3-phase VFD (2.2 kW) for a 3-phase 2.2 kW induction motor. I will use a torque transducer between the induction motor (load) and the test motor (DC motor, 2 kW). I set the VFD to torque control mode with minimum and maximum values, and I will use a braking resistor as well. Can anybody give me any suggestions on whether I should set the minimum value to 0 or 50% of the motor-rated torque, or any ideas on how I should control the torque?
