mrfailure
Materials
- Aug 7, 2011
- 813
ASTM E140 specifies different minimum indentation loads for Vickers hardness in order for the measurement to be considered valid to use for conversion to other hardness scales. These minimums are:
Non-Austenitic Steel
Of these, only copper shows different hardness conversions using different loads.
Since Vickers testing is supposed to stay proportional no matter what load is applied, I wonder about these limits. The aluminum 15 kg limit is absolutely nutso and would never be used it the real world (not to mention the white iron 50 kg minimum load); users mostly just ignore that limit and use the conversion when they are perform microhardness testing. At the same, testing has shown the proportionality deviates at low loads, certainly by 25 g. I think a case could be made that for all conversions in the spec applying a minimum load of 100 g would be reasonable. Thoughts/comments?
No limit
Nickel Alloys1 kg
Cartridge Brass (70-30)No Limit
Copper100 g
White Iron50 kg
Wrought Aluminum Alloys15 kg
