Hello all, when sizing a flange per ASME VIII-1 appendix 2 for use in B31.4 what is the appropriate bolt design stress (Sa and Sb). B31.4 does not address this like B31.3 304.5 and design factor x minimum yield strength seems too high.
GD2, thank you for the reply. I wasn't certain if the values used in the calculations would be different than what's published in II-D because my design code is B31.4. In B31.3-304.5.1 it clearly states "using the allowable stresses and temperature limits of this code", but B31.4-404.4.1 does not state this.
@Littleinch, I was designing a large diameter slip-on flange. It exceeds B16.5 and it is not listed in B16.47. Additionally our customer will not accept "industry standard" slip on flanges.
I'm intrigued as to the size and pressure rating for a B 31.4 system.
Why will the customer not accept standard flanges? Anything flange wise designed to ASME VIII is usually a lot bigger and thicker unless you specifically design for a pressure instead of the set pressures.
I am not certain why the end user is not requesting standard flanges. As a manufacturer, we work with the distribution network and not directly with the user, so typically, we do not get all of the information upfront. We were simply told the flange design must be validated with appendix 2 calculations, and that the old tube turn/taylor forge/"industry standard" large diameter slip-ons are not acceptable.
Slip on flange suck IMHO anyway, but yes there don't seem to be any standards for them.
Should move to weld neck.
But they pay the money, they take the costs, but presumably you are then stuck with B16.47 BCD and number of bolts and diameter of bolts to mate to the matching flange or do you need to provide a pair?
Madness.
