I'm working on a research problem that involves a mechanically interlocked viscoelastic damper. In the experiment I connected the the damper to the universal testing machine using brackets that are bolted to the damper and the machine. because of the interlocking nature of the device the flanges where moving outwards in a rigid body motion because the forces where not completely vertical on the bolts + the bolts where not tightened with enough pre-tensioning force. I can simulate the behavior by using a pin connection as shown in the attached image but the issue is that it doesn't offer any resistance in the lateral direction that is offered experimentally by the bracket. I'm trying to use a spring element but it's not working.
Any ideas on how I can solve this problem?
Thanks!
Thanks!
