NickParker
Should I compare the VT-C signal to the VT-A signal for sync check ? or VT-E in comparison to VT-A?
Similarly for VT-D to be compared with VT-B for sync check? or VT-F to be compared with VT-B?
Only at CB-C and CB-D locations it is possible to alter the speed/voltage using the speed/voltage adjustment selector switch?
Is there anything else that needs to be taken care of?
