VOLUME NX3
TomMtz
147
Friends
I tried to use volume values in the expression chart for calculating a height in other sketch (h=Vol/Diam^2*Pi/4)however when I change other dimension, the program launch an error message and all the archive "die".
Some one of you combine volume values in a similar case?
Thanks for your help.
It works OK for me, but just to make sure that the formula evaluates correctly I tend to overuse parentheses so my expression reads:
h=Vol/(Dia^2)*(pi()/4)
Anyway, attached is a simple model doing what it appears that you are asking about (edit the size of the Cylinder and the sketch updates).
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
John
I wrote this formula and still launch: "Error recovery completed for the following error: There is an object which depends on itself", it happens when I change a value from other sketch.
John
I omit some steps for my question:
1.-I made a sketch (1) (rectangle)
2.-revolved this feature
3.-calculate volume
4.-add value in an expressions chart
5.-I made other sketch (2) (rectangle)
6.-apply formula to calculate height using the calcutlated volume (h=Vol/(Dia^2)*(pi()/4))
When I change other value in the first sketch the program launch the error message.
If you are sketching 2 rectangles, where does the value of 'Dia' come from?
This sounds like a circular reference, i.e., you're attempting to edit something based on some value derived from the object you're editing.
From looking at your equation I get the feeling that you may be trying to create a 'cylinder' whereby if you edit it's diameter, that you want it's height to change based on the volumn change which resulted from the change in diameter. Sorry, but that won't work.
Now if this is an attempt to 'optimize' some aspect of a model, there are ways to do that, either by purchasing the 'Optimization Wizard' (and extra cost item) or by using the 'goal seek' feature in the Modeling Spreadsheet (which is a 'freebie').
John R. Baker, P.E.
Industry Sector
Cypress, CA
C
when I drew the first sketch I add width and height to calculate volume.
In the second sketch I only used the volume for the first sketch when the sketch was created.
John
Thanks for your help, and its a shame that NX3 doesn´t work in this aspect.
I will try to change the modeling estrategy.
Thanks a lot for your comments
Tom
Since your model sounds very simple, could you upload a copy so that we could see exactly what it is that you're trying to do?
John R. Baker, P.E.
Industry Sector
Cypress, CA
John
Sorry, but in the company we can´t send files in our e-mails. (law restrictions).
But I´m glad whit your help.
Well look at the part file I posted and try and figure out what it is that you're doing which does not look like what I did.
John R. Baker, P.E.
Industry Sector
Cypress, CA
John
I have the solution, instead of using a circular reference, I wrote:
(((DIAM1)^2*(pi()/4))*LONG)/(DIAM1*2)^2*(pi()/4)
And it works very well! instead of using the volume from expressions chart, those commands calculated de volume for the first sketch and height in the other sketch without corrupt the file.
John
DIAM1 - ONLY IN SKETCH 2 to calculate volume of sketch 1.
Thanks for your help. its time to leave the office
See you
Tom
