Vortex shedding critical velocity.HELP!!
Someone11
15
How is the new critical velocity calculated after the term in the square root is found negative. As far as i know,normally the second critical velocity is taken as 6.25 times the first one. But here the result is different. Can anybody guide me through this?
Maybe some conversion factor is involved in this. I too couldn't get any reference regarding this step.
There are a number of design standards addressing your (OP's) question.
The reponses can only help if you clearly identify what you are trying to accomplish.
Vcrit in that last equation is ft/sec, as opposed to mph in the first equation. It's the same speed, not the second critical speed.
