VRF Heat Pump - Cooling in Low Ambient Temperatures 2
nuuvox000
Hello, I have some areas in a building that will be in cooling mode 24/7/365. I was looking at the operating range on the Fujitsu outdoor VRF units and they are only rated for cooling between 23°F to 115°F. Why are they only rated down to 23°F for cooling mode? Wouldn't it cool even better the colder it gets outside? Thanks for your help!
The refrigerant gets too cold... you need a differential pressure.
Mitsubishi has units that come with a low-temp kit (baffles to keep the wind away) that are rated to around -20°F. Look at the PKA/PUY models. They also modualte and shut off the condenser fan to keep the refrigerant at a minimum temperature.
Refrigerant needs enough delta temperature to evaporate in the expander; otherwise, the compressor will be trying to compress something that's mostly liquid, which is REALLY bad for the compressor, and pretty much chews up the SEER.
TTFN (ta ta for now)
Thank you, that helps a lot!
