VT Error
Cerkit
100
Does anyone know how I can calculate the Voltage Error and Phase error for a VT at a given output voltage if I know the error for other output voltages?
So in this instance a single phase VT has voltage error +0.8%,phase error 15minutes at output of 20VA with unity power factor. For an output of 110VA unity power factor the voltage error is -0.1%, phase error -3 minutes.
How can I calculate the the voltage and phase error at an output of 150VA unity power factor?
You said "output voltages", but it sounds like you want to calculate the accuracy at a different burden (power output).
The accuracy of a VT (at a given voltage) moves linearly/proportionately with changes in burden (VA).
So you can plot the 2 points that you know and then extend the load line to 150VA.
This bulletin talks a bit about this. The ratings are in IEEE-speak, but the concept is the same.
So if I plot two graphs, one Verror vs Burden and another Phase error vs Burden I can extrapolate, is this correct?
No, please see the link I posted above. The graph is phase angle error and ratio error plotted at various burdens.
