VUMAT
Magomandril
Materials
Apr 25, 2007
1
Hi everybody:
i've just started to implement a vumat for abaqus and as my first try I made an elastic material vumat. As the program compiles it says that it cannot link, but I don't know why it happens. Does anyone have an example similar to mine? Would you mind to borrow it?
Thanks!! :)
It does not link because the program cannot find the required libraries. Typically this is caused by not having set the system variables to contain the path to the libraries folder.
You should look in job_name.log to see the cause of linking error. If it says it cannot find some library you have to update the system variables to include the path to the library. You have to restart ABAQUS in order to make it aware of the system variables changes.
