I am working in the metal forming simulation field. I have simulated multiple forming processes in the ABAQUS FEM program. Now, I have tried to implement a ductile fracture criterion into the ABAQUS using the VUSDFLD subroutine. The subroutine works without error in the simple model and the research model. however, when the mesh is getting fine, the run is aborted with different error codes, like as "The executable explicit.exe aborted with system error code 3." I have noticed the high usage of memory so that all 16 GB RAM memory is engaged when the job runs. Does any body could help me? If I upgrade the RAM into 32GB capacity, will it work?
