VUSDFLD VGETVRM
V_S_B
17
how to use VGETVRM to get temperature , strain and strain rate valuues?
The interface of VGETVRM utility routine is:
call vgetvrm( 'VAR', rData, jData, cData, jStatus )
Data is provided to this routine via output variable key VAR. Available output variable keys that can be useful for you include:
LE - logarithmic strain components
PE - plastic strain components
TEMP - temperature
Unfortunately strain rate (ER) is not available in VGETVRM.
An example of the use of this routine for logarithmic strain components is:
call vgetvrm( 'LE', rData, jData, cData, jStatus )
@FEA way
Thank you for your reply.
Is there any method to get strain rate ER.
I'm afraid that the only way to bypass this limitation is to use Abaqus/Standard and USDFLD instead of VUSDFLD. That's because GETVRM utility routine used in conjunction with USDFLD doesn't have such limitation regarding available output variables.
