Raccoon678
thread167-146763
I am designing 5 inch reinforced concrete walls that only require minimum reinforcement. I am using wire mesh that does not meet the minimum reinforcement ratio hence I have added #4 vertical (longitudinal)rebar spaced at 24 inches o/c and #3 horizontal (transverse)rebar at 20 inches o/c. This does not meet the maximum ACI spacing of 18 inches between the rebars but, considering that I have fabric mesh between the rebars, can I ignore the 18 inches maximum spacing as it relates to the space between the rebars?
