Warren Truss
Yes. Your truss would be properly called a Modified Warren Truss due to its vertical members. A simple Warren Truss has only intermediate inclined members.
what direction would you apply the "wind" load ? in the same direction as the other loads ?? is it like a down gust load applied to the surface between the truss planes (similar to the snow load) ?
terminology is a little "sloppy" ... 6 bays have 7 nodes
