Dear members:
I have an idea of using water brine solution for freezing plastic water bottles,how practical such design?
I think about using same idea of vapor compression refrigration unit but the evaporator (will not be an insulated room with crazy fans running inside, with the importance of insulation and long time to get the job done) ..
instead it will be insulated water brine solution basin with evaporator coils running inside in the upper side :
The coold energy can be stored for long time .
Water specific heat is much higher than air ,which means that even with some air leaking into the basin it would not effect the process as in the case in walk-in freezer.
Thermal conductivity of water is much better than air which might make shorter time to get job done. ..
I know that some corrosion issues might make this unpractical...
But anyway, how such design is practical?
Thank you.
Thank you.
