Hello
So I'm doing some initial research for water distribution system for two groups of summer houses.
We have access to water @150m in the mountain above, then there are planned 12 houses @100m and 30 houses @70m.
First I was planning to use the same tank and pipe the first 900m and then split the pipe in two.
After simulating this in Pipe flow expert I can run into the problem of possible low pressure @100m if the 30 houses are using too much water.
Do you have any general recommendations, should I just run two pips all the way or fix this issue with flow rate and pressure reducing valves?
See diagram attached
It would cost about 900m extra of 50mm piping vs 900m of 63mm and valves.
Are flow rate and pressure reducing valves prone to failures?
Thanks in advance![[bigsmile] [bigsmile] [bigsmile]](/data/assets/smilies/bigsmile.gif)
Thanks in advance
