niallmacdubhghaill
Chemical
Im looking into water hammer at the moment. I am trying to figure out whether or not my lines are at risk from water hammer stresses.
I have found a design guide which tells me that if t>3L/Vsound then water hammer is not a problem.
t = valve closing time
L = length of column of fluid (pipe length)
Vsound = velocity of sound in fluid
then Vsound is given as sqrt(k/rho) where rho is fluid density, and k is the bulk modulus of the fluid where the bulk modulus is given by k = -V dP/dV.
This is pretty much where I get lost.
If my fluid is an oil, with density 840 kg/m3 and is essentially incompressible (=> Zl=0) haw do I calculate k and thus Vsound to find out if I have a water hammer problem?
Any and all help appreciated!!
Niall
Niall
