geoffthehammer
- Jan 28, 2005
- 77
If water is flowing through an orifice under pressure and forms a jet. Is there a way of predicting at what distance from the orifice the jet will cease to be a coherent stream and break up into small droplets. In my particular case the water is pressurised at 6000psi, the orifice is 0.003" diameter and the jet is vertically downwards
