SteelPE
- Mar 9, 2006
- 2,759
I have a project where we are pouring a large exterior slab. A question came in from the owner with regards to the water reducer being used for the project. His concerns revolved around another project that was constructed a few years ago and the fact that the slab has surface cracking and this surface cracking is being blamed on the water reducer.
I am no where near a concrete additive expert. This is the first time I have ever heard of this issue with regards to a water reducer. I actually thought a water reducer would help with cracking over time (shows what I know).
Is the problem referenced, water reducing additives causing surface cracking over time, a real issue or is this something that the owner is making up? Also, if it is a real issue, how do you prevent this from happening while maintaining a workable concrete mix?
