Geee Concepts
Good day.
I'm currently designing a pumping system for potable water supply in a rural community. Water from the the spring at the bottom of the mountain will be pumped at the top. The area from the spring has an estimated total elevation of 120m, and 1500m pipe length (200m on a slope @ 120m elevation and 1300m horizontal) using a 1" HDPE pipe to be supplied to a 1.5 cu.m tank. Water to be supplied would be at a a rate of 2 cu.m at about 1.2 m/s velocity. Now based on calculations, I would need a 2 HP pump with a 240m .001 cu.m/s discharge. I know this is not possible since it would be almost impossible to find it in the market, and most probably the piping at the pump discharge would not be able to hold the discharge pressure. Can anyone enlighten me on this? This would be my first time designing such application.
Thanks.
Good day.
Thanks.
