Dan_C
- Aug 5, 2020
- 2
I need a compression spring which will not bend laterally when an uneven load is applied. I.e. It moves in only 1 axis as much as possible.
Of course, if a core/shaft is inserted in the spring this problem will be solved, however this won't be possible for this particular application.
I'm just wondering, will wave springs provide more resistance to lateral bending than a traditional compression spring? Or are there other types of springs which may be more suited?
Thanks in advance
Thanks in advance
