KHCEng
Aerospace
- Aug 22, 2014
- 2
I have a machined rib and want to check the web buckling. What dimension should I use for the web width? Usually I would use the dimension from the mid-line of the surrounding stiffeners but a less conservative view may be to use the dimension from the inside surface of the stiffeners. What is the general view?
Also rather than assuming SS edge conditions is there a way to calculate a rotational stiffness value so that the edge condition is somewhere between SS and fixed.
