I have a P1 vessel (2.5" thick) that requires some build-up of the internal wall due to wear. I have a groove welding procedure that allows for grooves up to 0.68" and all fillet welds...a PWP-7 procedure here in Canada. If my procedure qualifies me for all fillets up to 1/2" of deposited metal, can I use the procedure to build-up the wall of the vessel up to 1/2" with applied fillets, or does the limitations on groove weld size apply?
Thank you to any that can provide an opinion on this matter.
Blizzardo
Blizzardo
