dcarr82775
- Jun 1, 2009
- 1,045
I do not get into AASHTO much and I want to see if I am interpreting something correctly with respect to welding and fatigue. It isn't a bridge, but it is supposed to be designed per AASHTO.
I have a wide flange that is to be hung via a vertical knife plate located over and parallel to the web. I believe the weld of the knife plate to the wide flange falls under the condition shown in 5.4 of Table 6.6.1.2.3-1. Am I correct in assuming that the live load stress range in the weld metal needs to be less than or equal to 10ksi? I ask because it makes a fillet weld virtually impossible to use in this situation.
