Mohsen_81
- Dec 14, 2020
- 26
Hello all,
To install a replacement vertical vessel on existing anchor bolts, vendor suggested that legs be split into two parts. The lower part will be delivered to the site sooner to be installed and then later the reactor will be welded to it.
The suggested welding method is as below drawing. Can you advise how can the suitability of this design be checked? Should it be checked with any standard or code, or should it be modeled in any software?
