Soicey75
- Sep 17, 2018
- 7
I NEED HELP UNDERSTANDING THE CORRECT WELD SYMBOL. I WANT A 3 INCH WELD STAGGERED ON EACH SIDE OF A HSS BEAM RUNNING PARALLEL TO THE W BEAM IT SITS ON AND WILL BE CONNECTED TO. I WANT A 3 INCH WELD EVERY 12 INCHES STAGGERED SO TECHNICALLY ON ONE SIDE YOU WILL SEE A 3 INCH WELD EVERY 24 INCHES. VIEW THE PICTURE ATTACHED WERE I HAVE A TOP/PLAN VIEW AND ELEVATION VIEW. WITH THE HSS IN RED, ON TOP OF THE W BEAM, AND THE ORIGINAL BEVEL-FLARE WELD I WANT FOR TWO SIDES BUT DON'T KNOW HOW TO MODIFY IT TO BE STAGGERED.
