RJW000
- Jan 14, 2021
- 21
I'm looking at a welded flat head on a vessel. This equipment is low-pressure (~6 psig), not code-stamped. The welded flat head (~100" OD) has four C-channel stiffeners welded to head.
Does anyone have any recommendations to evaluate this component and determine a required thickness (only load case is int. pressure)? If it was a VIII-1 vessel it looks like U-2(g)/App-46 may be the correct approach.
Using VIII-1 flat head calculations with no stiffening effects results in required thickness much larger than the original design thickness.
