mech8790
- Sep 11, 2017
- 59
Hello everyone!
Quick question for you. Can the shell of a pressure vessel been welded to the base plate like it is shown on the attached photo? I think of getting the calculations done in accordance with UG-34. The base plate is bolted to the transportation frame so from the pressure point of view this welded flat end shall be calculated as circular? Also, I couldn't find any reference to weld detail between the shell and the base plate in the Code. I am thinking of V prep the end of the shell and get full pen weld done there with a fillet. The size of the shell is relatively small, so I can't get access to it from the inside of the pipe.
