I'm designing an embedded base plate with anchors to resist tension due to column moment. But, because the base plate must be flush with the floor, I must weld the 3/4" dia. (F1554-GR36)threaded anchor to the bottom of the 1" thick base plate.
To increase the weld capacity, can I insert the threaded rod into an oversized hole in the base plate with a plug weld? If so, how do I calculate the weld capacity?
