RabitPete
- Nov 24, 2020
- 109
Most discussions I've seen regarding welding in k-area were about stiffener plates. Any issues with starting a shear tab weld right from the point of tangency between the fillet and a web?
Also, part 9 recommends 1/2" clearance and I am a little short under the bottom side of the top girder flange. I assume recommended is not required? The issue is that top flanges of the beam and girder must be flush, so I cant lower the shear tab without reducing its height, and reducing the shear tab height will reduce the edge distance or bolts spacing.
