Everynameistaken
Posted in the metals section but not too many responses!
I am a structural and I need to weld a threaded weldlette to a 36" pipe to use as a float, so I can fill the pipe with expanding foam and then thread in a cap to seal up the access port.
My question is:
I am specifying pretty generic low grade pipe, there is almost no pressure load on the pipe as its just the static water pressure so 1m of water head. The pipe is carbon steel to ASTM A252 or similar with 240 Map yield. Can I weld ASTM A197 Cupola Malleable Iron to the carbon steel?
If so, is there anything special about the weld?
If not, what is the type of threaded weldolette that I should use instead?
Thanks Very Much
