Some supplier is having problems welding an aluminium vacuum vessel.
The hydrogen from the air moisture is diluting into the melted aluminium during the welding process. There are large bubbles when it solidifies.
X-rays are showing the problem.
The new approach is pre heating the welded parts.
Does anybody have any tips to get a proper welding for a tight vacuum vessel?
The porous seam will be a problem for the vacuum
thanks
thanks
