May 14, 2011 #1 marBz Mechanical Apr 20, 2011 38 0 0 PH any one know how deep is the water level from the land surface?? im from the phil.
May 14, 2011 #3 bimr Civil/Environmental Feb 25, 2003 9,299 0 36 US It can vary from a few feet to over a thousand. You should check with a local water well contractor. They usually have records of wells that are drilled in the local where they are doing business. Upvote 0 Downvote
