Application
Boiler Feeding - Water supply to High Building, Temporary water supply
Features
The horsepower of the motor is decided by the boiler’s operating pressure (kg/㎠).
The water is supplied at a temperature range from 90℃ to 95℃.
(only when Fu-jet is installed)
Compact and easy to install, check and repair. Lower malfunction than multi-stage pumps.
Cost saving thanks to horsepower saving of 50% compared to other pumps
