we have too many shims in a thicker size and want to grind these down to the thinner size, all other dimensions are the same except thickness. Going to be wet Ground as the 52100 material is already HRC 58 Min.
I am thinking that at a minimum a percentage of the shims need to be etched for grinding burns, and a sampling for Hardness (surface). What about a Temper at say 300F??
