This is a 230/400 V diesel generator (QAS 100 - 100 kVA). Which standard specify a ground grid resistance value of reference for this kind of installation (isolated)? I was reading IEEE 142 and 4.1.3 "Recommended acceptable values" specify:
"Resistances in the 1 ohm and 5 ohm range are generally found suitable for industrial plants substations and buildings and large commercial installations"
However, I understand that this apply for a installation which is connected to the distribution system. But what would be the value for the case where the system is energized only from a diesel generator?
Thanks!
Thanks!
