I know that over time a rubber impeller is going to get worn down and therefore performance of the pump will drop, which is why there is a recommended about of hours before replacing an impeller. But, what is the actual reason for this normal performance loss?
I would assume the rubber just gets worn down by the friction on the cam and then there is less compression between the impeller and cam and therefore decreased performance?
