Haroon Baloch
In all 4-pole ABB MCCBs, above a certain range, it is mentioned that that there is an option to choose 50% or 100% Neutral protection. Specifically, it says "The four-pole circuit-breakers are always supplied with the neutral protected by the trip unit and with protection of the neutral at 100% of the phase setting for settings up to 100 A. For higher settings, the protection of the neutral is at 50% of the phase setting unless the protection of the neutral at 100% of the phase setting is required."
What does it mean to have Neutral protection at 100%, or 50%, of the phase setting? If there is any manual where I can read about this type of protection, then please give reference to it.
