ENGRANIA
- Dec 17, 2008
- 34
What does the best program which shall be used for performing the finite element analysis for column supported cone roof structure with trusses ???? The tank will be 30500 mm diameter snd 14 m long
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
ENGRANIA (Mechanical) said:...And why self supported truss roof instead of column supported roof for 30m diameter
My opinion is ,this is medium size tank..the roof can be with single column supported cone roof with radial rafters..But the total weight will be more then self supported truss roof type.IFRs (Petroleum) said:For a tank this small, a single column with radial I-beam rafters is an easy hand calculation.
