bizkitgto
Chemical
- Jul 16, 2012
- 4
I’m working on a project where we have a large LNG Storage Tank at an LNG Facility. There are several submerged pumps, and each pump can be pulled out and replaced with a dummy. It also calls for a “dummy pump” to be installed for the LNG Cooldown/first-fill. The dummy pump
appears to be a cylinder that just weighs down the foot valve to allow liquid to flow up the pump column. I don’t understand why this is part of the startup.
Can someone explain why we need a dummy pump and what it is supposed to do? Thai appears to be only needed during the tank cooldown and facility startup.
Thanks!
Thanks!
