yamoffathoo
- Sep 19, 2008
- 87
A 40ft x 32ft high diesel storage tank at my plant has provided excellent service since 1978 with some minor pitting on the underside of the floor plates, which have been patched.
Recently, localized thinning below 0.1" of the 0.25" outer annular ring (chine) adjacent to the 12" wide concrete cut-out for the 3" bottom draw-off pipe has raised some concerns.
Appendix O of API 650 indicates (to me) that the loss of support and torsional resistance of the chine and critical zone over the cut-out is provided by the draw-off pipe and structural bracing that is welded to the underside of the middle of the chine.
In my opinion, localized thinning of the chine at the edge of the cut-out should not require a major alteration to replace this section of bottom plate.
Has anyone performed a Fitness for Service Assessment for localized chine thinning at cut-outs and if so, is there a hand calculation that can quantify the extent or span of allowable chine thinning in this area rather than a parametric study using FEA?
