What is the difference between ASHRAE fitting SR4-2 and ER4-2?
Kapp
Both look identical to me, but the pressure loss coefficients are different. I'm trying to understand why the pressure drop would be different if the air flow was going to a fan or coming from a fan. It's not a converging/diverging difference, because that is accounted for in the A0/A1 value. ER4-2 is under negative pressure, but the lighter density should be accounted for in the velocity pressure. I've attached images of the fittings and the loss coefficient table. Any thoughts?
I'd guess the difference in velocity profiles at fan discharge vs fan suction.
Thanks Mint, I thought that as well, but ASHRAE has an entire section of fan discharge/suction fittings. Which implies that these fittings can be anywhere in the system.
