NorthCivil
- Nov 13, 2012
- 562
I'm involved on a project where there is existing Glass-fibre reinforced cladding panels that are failing. rising up 15 odd levels on a building in the city. size of panels, about 3m x 1m (approx 3.5ft x 9ft)
we will be removing and replacing, the client hoping for something that looks the same. the look from the exterior is textured plaster, which has been applied around the building, over exterior concrete and GRC cladding panels alike.
client is pushing for these locally available aerated concrete panels. primarily because they are light and cheap. what these are, is aerated concrete, strength of 4MPa, 50-75mm thick, with a grid of steel reinforcement in the middle. the reinforcement is a grid of 3 or 4mm steel mesh in the centre. 150mm x 150mm grid. these get screw fixed back to the building, right through the panel
I've done my homework on these and im not too keen. on the lightweight concrete, as it is very porous. nor am i keen on the strength. also not keen on the reinforcement in the panels, which is galvanized steel, but because it is so thin with porous concrete, will surely be getting attacked. worth mentioning we are within 300m to the sea.
i have proposed to the client maybe we can form our own panels of ordinary 30mpa concrete, using stainless steel reinforcement. likely a 150x150mesh of the same size. with potentially some extra reinforcement near where we do anchor points. anchors will likely be the same, screw fixings right through the panel. M8 epoxy anchors or similar.
wondering what is a reasonable minimum thickness to target? does anyone here have experience casting very slim concrete, and have any tips to offer?
because we will be laying these panels over battens and have the opportunity to connect back to building at regular intervals, the panels will be under minimum stress. the real concern is what is a minimum thickness of concrete that can remain reliably cohesive, as it hangs 200ft above pedestrians in the city?
