Tomfh
- Feb 27, 2005
- 3,582
In regular sand:cement grouts and mortars you see increasing compressive strength with increasing cement quantity. Eg a 3:1 sand to cement ratio gives you a stronger grout than 6:1. However I understand pure cement is weaker than a strong sand/cement grout (correct me if I’m wrong there)
At what point does extra cement result in diminishing returns?
Assume regular quartz sand and a normal water to cement ratio. Nothing fancy.
