What software or methodology do you use to assess (risk, benefit) of your modification in plant?
bboosstteerr
17
Dear all,
Supposes you already improved/modified some equipment, then how do you assess the risk or the benefit for the overall system/plant? any references thank you.
We usually do the PFMEA upfront before the change then look at Cpk afterwards to assess the benefit. Only software is MS Access & Excel.
A table in your favorite document editing software (whatever that might be, we use LibreOffice), plus the relevant standards in front of you, plus a healthy dose of common sense and experience.
As others have mentioned, it's not so much the software, you can take legible hand-written notes and it's just as legitimate, but it boils down to the meat of the discussion of the professionals sitting down and discussing what could go wrong and who/what will be affected by those failures (or misuse). It should be thorough, but realistic. You are the one that needs to determine how far down the chain that needs to be assessed, IE single fault, etc.
Looking at your original question again, are you asking about true risk analysis and risk management, or is it simply a bullet-point list of pro's and con's to justify an update?
are you talking about a cost/benefit study, or a trade study ? these are different to FMEA (which essentially the probability of failure of the system)
a cost/benefit study is straight forward, no? if not, look up examples.
A sensibly done FMEA can be very useful. A badly done FMEA is a waste of everybody's time. Note that a good FMEA does not have to be complete, because some FM are obviously inconsequential so you don't need to complete the table for them. That is, you should work across the table rather than down it.
Cheers
Greg Locock
surely anything badly done is a waste of time ?
I mean how true/close the estimation from doing such analysis for the cost and risk
the resulting accuracy of an analysis for cost/risk is the same as any other analysis ... as good as the input data ! One way to improve things is to do a sensitivity study on the inputs ... which affects the answer more ? Maybe look into how insurance companies assess risk ?? (I mane they make money out of risk, so they've got to know something about it). or project management (managing risks).
do you have any books recommendations sir that you would say a must have?
simply put, no.
it's help others to know more about what you're trying to do. You've asked a very general question. Are you interested in risk (ie damage and costs associated) or RoI (return on investment) ? Are you embarking on a change, or trying to justify (or undermine) a previous change ? Has you company done similar changes before, or is this a shot in the dark ?
Have you done a simple google search (for say "cost benefit analysis") ? Then ask us which of the promising hits we'd recommend.
ok thank you sir sorry for my vague question i'll try to refine the next question.
"do or do not, there is no try" ;)
