What type of coupling to use to connect dn 600 schedule 10mm and dn 600 schedule 15 mm di pipe 1
jithin john
16
hello every one ,
What type of coupling can be used to connect dn 600 schedule 10mm and dn 600 schedule 15 mm di pipe.
please also mention the od range .
thank you
No need any coupling if it is a metallic pipe, the higher schedule needs to be tappered to the thiner thickness and welded.
It's a DI (Ductile Iron) pipe. You can't weld it.
thankyou every one for your responses
is there any vjc coupling available for 635-640 od range
Search for and then ask the vendors.
This is not what this forum is here for.
Please do you own work first then ask us if it correct.
We do not work for you....
VJ coupling is available for 635 mmO.D. Ductile Iron pipe..
file:///C:/Users/user/Downloads/Large-Diameter_Couplings_OD3556816_VJ_DS_0917.pdf
