In the IEEE Red Book there is this statement that it does not clarify. Can someone explain?
"When applying a current-limiting fuse of a given voltage rating over 600V on a circuit of a lower voltage rating, consideration should be given to the magnitude and effect of overvoltages that will be induced due to the zero current forcing action of the fuse during the interruption of high-magnitude fault currents."
